designing a wall assembly
Let's compare the following two wall assemblies listed from exterior to interior: 1. concrete, insulation, and gypsum board and 2.stucco, insulation, and concrete. Therefore, in case one, the insulation is inside, and in case two, the insulation is outside.  Case one is good because the insulation may not fall where the dew point temperature is.  Case two is good because the concrete is not exposed to freeze-thaw conditions.  So, which is the more practical wall assembly to use?
RE: designing a wall assembly
Have you ever looked at how the walls in a house are constructed?  Which combination is used?  Why do you think that is?
Patricia Lougheed
Please see FAQ731-376 for tips on how to make the best use of the Eng-Tips Forums.
