Insulation green stuff
3
I have a significant number of control cable wires.  Standard gray control switch wiring #8 and #10 that is oozing a green sticky substance.  It has no odor.  Has anyone seen this before or know what it is?
RE: Insulation green stuff
Never heard of it.
I think you may get more responses in the electric power engineering forum.
Posting a couple pictures wouldn't hurt either.
Long Shot — “Green-goo ooze” is a slang term for electroendosmosis, which is mentioned in an NEC fine-print note.  For it to occur, though, there has to be DC potential, moisture and thermoplastic {e.g., PVC} insulation.
99NEC310-13. FPN: Thermoplastic insulation, where used on dc circuits in wet locations, may result in electroendosmosis between conductor and insulation.
Suggestion: Visit
http://www.edstubbs.com/id22.htm
for:
(under "Stranded or Solid Conductors on DC circuits 6/30/02")
I have seen this in older power plants on 125 vDC circuits as mentioned by busbar and jbartos -- as their explanations imply, it is a chemical reaction with the copper (the source of the green color -- my chemistry fails me but I think it's a reaction with the chlorine products in the insulation as a result of the DC in the presence of moisture)...  as I recall, it is also slightly acidic...
