dc current amplifier
I need help in creating a dc current amplifier.  The current/voltage source would be a battery.  The amplifier could be multi-staged.  I would like the output current to be in the range of 50 - 100mA, and the input current being in the range of 5 -10 mA.  Could someone make a recommendation of what type of amplifier circuit would be best suited for my needs?  Resources would be helpful too.  Thank you very much.
Nathan (s0naharn@yahoo.com)
RE: dc current amplifier
thank for the sites, they proved helpful!
How much voltage drop can you afford on the sense R ?
Is the sense resistor in the GND or in the + or - supply line or floating ?
How much accuracy do you need ?
Is trimming/adjustment/resistor selection acceptable ?
If the output is processed by microcomputer, it can store the calibration factor, too.
<nbucska@pcperipherals.com>
