DOE with repeated responses
Most DOEs I am familiar with involve only looking at 1 response for each test run. Is there any way to incorporate some sort of repeatability test inside each test run's y response?
RE: DOE with repeated responses
Cost of running the tests should be another consideration. If inexpensive, you could run multiple samples using the same factor combinations and see how the results compare. If it is expensive, I would recommend using a classical test to verify the DOE results.
Why is are they based on logarithmic functions?
I can understand wanting to see which drowns out which (signal vs noise). But I fail to see why that sort of function is used.
