Turbulators To Improve Heat Transfer
I am looking for design data for the application of Turbulators (spiral section incerted into last section of third pass smoke tube)to improve heat transfer in the last tube pass of fire-tube boilers.
RE: Turbulators To Improve Heat Transfer
www.fuelefficiencyllc.com/feturb.html
Hope this helps.
saxon
I have several papers, which I use when I design fire tube boilers for enhancing heat transfer in the convection tubes. I could scan them and send them to you if you want.
Bogu
Steamtech
i know of a site that had bad boiler water, which led to tube replacement (firetube boiler). turbolators were a new product at that time (invented by a priest, i think!) and the boiler owner opted to have them installed in the boilers. within a couple of months after installation (now winter time), the gas company sent a couple of individuals to the owner's bldg to investigate for potential problems - i.e. why is gas consumption suddenly reduced? gas company reps found nothing wrong and everything seemed to be in good shape. so they inquired with the owner mentioning that gas consumption was reduced 50%. how come they asked? the owner was most pleased with the boiler retube and the installation of the turbolators. in fact these refurbished firetube boilers were operating signficantly better than originally designed.
-pmover
I have reduced stack temps from 310 deg c down to 180 deg c by fitting these items. Steamtech I have never designed a coal fired firetube I have only designed them for gas oil and sawdust. I will scan and email the papers in the next day or so.
Bogu
ALL of the turbolators I've purchased over the years are designed to be an interferance fit into the bore of the tube.
Don't ever believe that you fit one of these items just to stir up the contents of the tube!
It is a good idea to review the published test data and draw engineering conclusions from the test data. If one doen't believe the test data, then all it takes is running your own test to prove or disprove the data.
The Bergles papers show very high increases in flue gas pressure drop when turbulators are installed in an interference fit, but if a slight gap is provided then the pressure drop does not increase as much and thre is subatantially the same improvement in heat transfer.
I stand by my comments!
I assume this data refers to spiral wound turbolators, in which case you may be correct, however with the more effective wire wound turbs you may find that I am correct.
Try using the information supplied by your peers as a basis for future development.
