Engineering Drawings
I'm trying to locate scale drawings with all the relevant dimension for a Ford Sierra 4x4 engine, transmission and final drive units, the engine would be the 2 litre and not the 2.8 / 2.9 V6.  Can anyone help or point me in the right direction?
All the best
DC
RE: Engineering Drawings
I didnt know that the Sierra ever came as a 2l 4x4.
I remember the xr4i with the v6, they tried a Hart (twin turbo I think) but I never came across that outside Ford R&D, and then went with the cossie - was that a 2l?
Depending on what you are trying to do, remember that the Granada/Scorpio of the period had the same drivetrain so info on that might also be of use.
Thanks Mark
There are 2l 4x4's out there as i just missed out on one.  I'm building a special and wanted the running gear and engine from the car.
Thanks again, i will look into the Granada/Scorpio side of things.
All the best
Dave
