Specific table properties
Hi everyone,
I would like to know how can I make table from assembly where I used one component 4-times but I need show in table only twice. some kind of filter
Thanks for your help.
RE: Specific table properties
This is how I would do this, modify the pattern, so that you see all required dimensions for this pattern including the QTY in the Pattern. Then enter family table without cleaning the screen, add dimension and pick the QTY of the pattern, this now shows up in the family table. Just enter the QTY you want for each indance.
Tofflemire
im4cad
Pro Design Services, Inc.
http://www.cadproe.com/pds/home.asp
1- Create a BOM table, define the repeat region and put the following text in the repeat region as following (use the TABLE -> ENTER TEXT -> REPORT SYM):
| rpt.index | rpt.qty | asm.mbr.name |
2- Set the attribute of the repeat region to NO DUPLICATES.
Now the table will show all the components in your assembly with the assembled quantity. But you don't want to show the quantity of 4 for the component having name 200-12345 (example) but a quantity of 2!
3- Click TABLE -> REPEAT REGION -> RELATIONS -> click on your repeat region and EDIT REL:
IF asm_mbr_name == "200-12345"
QTY = 2
ELSE
QTY = rpt_qty
ENDIF
4- Close and save the releations and go back to TABLE -> REPEAT REGION -> SWITCH SYMS.
5- Now in the TABLE menu choose ENTER TEXT -> REPORT SYM -> click on the second cell of the reat region and choose:
(from the right menu of PRO/E) rpt... -> rel... -> USER DEFINED -> QTY
Your table should be like this:
| rpt.index | rpt.rel.qty | asm.mbr.name |
4- Done. Go back to TABLE -> SWITCH SYMS.
Now you should see the quantity of 2 (instead of 4) for your part. For the other componets, the qty shown in the table are the right values.
I hope this is what you want to do.
Good luck
-Hora
