Overvoltage conditions damaging VFD's
I would like to see some opinions on whether a line reactor will really help in this situation. 1 300hp VFD and aprrox. 30 5hp VFD's fed by a 1500kva transformer within 30 feet. All of these drives have a history of overvoltage faults and many have been repaired or replace more than once. The facility is very close to a steel mill and the line voltage is usually around 500 volts. The VFD's will fault on OV at 544 volts. Thanks in advance for any enlightening discussion.
RE: Overvoltage conditions damaging VFD's
Are there capacitors, e.g. for power factor correction, involved?
When the next fault occurs, check the transient recorder for transient overvoltage. If it is there and if it is not in the milliseconds region, then a line reactor with 3 or 4 percent voltage drop will probably do the job.
If you have longer transients - well, I do not know what to do, really. More inductance than 4 percent might cause problems with the inverters since their input voltage drops too much when loaded. I once used a large DC choke in the DC link to make the inverter immune to PF capacitor switching, but that's a hell of a job.
I second the potential excess capacitors causing momentary or sustained overvoltage, but put main-transformer tap checks on the top of the list. Remember that—almost without exception—a primary-side powerdown must be scheduled before tap change.
It may be that the serving utility has local capacitors on their distribution system that are not disabled during light-load/low-var-demand periods. The capacitors may be unswitched, or the associated control scheme is not operating correctly.
The 544V-trip feature should be verified as indeed happening at the intended time and voltage level.
508 volts steady-state AC is often the consensus upper limit at 480V building service entrance. It may be worth experimenting with installing buck-connected transformers on a few of the smaller “problem” drives. Stock ratings are typically in the range of 12-16-24-32-48 volts. Check the drytype-transformer literature: for a smaller 3ø 3W load, two open-delta-connected buck/boost transformers can be used, or for bulk loads where a neutral conductor is available, three wye-connected units may be more cost effective. Double check the “new” voltage on the buck-transformer load sides before powering drives.
544 is less than +10% variance the utility supply will normally have on a 500V bus. I would look at the tranformer tap and adjust to 480 or even 475V first.
Some swithing suirges caused by the adjacent still mill may be involved? Is there a time delay on OV proteciton on the drives?
