Harmonic Analysis
Harmonic Analysis
Harmonic Analysis
Hello Friends,
I would need ur help in inputting vibration test schedule data for my harmonic analysis. I have a fuel rail, I found the resonating frequencies. I have my vibration test data given as follows for parallel to bore(vertical)
Frequency(HZ)  Accelaration(g)
20                3.3
500               3.3
800               7.1
950               4.1
1160              5.6
1375              6.5
1720              3.9
2000              3.9
Could someone help me how to go abt with my harmonic analysis, the rail is like a thin circular tube with 2 brackets.Appreciate ur time n help.
Thank u all
cheers
harid
RE: Harmonic Analysis
You use the spectrum response method by inputting the frequency-v-acceleration as your curve. Combine your results using SRSS, Sum of Root Sum Squared.
corus
http://www.corusresearch.com
Hello corus,
could u please elaborate it...or may be explain me how we can do that exactly in ansys..if possible steps to be followed in GUI.ur help is greatly appreciated.
thanks
harid
