Needed, Large Cross Flow Fans
I am looking for a manufacturer of large cross flow fans.  Also sometimes called tangential fans.  The application can fit up to a 44" long fan wheel.  The wheel diameter will probably need to be from 10 to 20 inches in Dia., package can accomodate a range.  I would like 45hp at 1800RPM at the fan to deliver ~18,000CFM at 4"h2o if possible or something in this ball park.  I am designing a cooling system to go on mobile equipment, so fan must be rugged and compact as possible.
If you have ideas on who could supply this type equipment please reply.
RE: Needed, Large Cross Flow Fans
Try www.eltafans.com or www.woods-fans.com they are both indutrial air movement manufacturers handling series production or bespoke one-off solutions.
John.
