Energy Audit equpiment
Dear All,
I am looking for a list of insturments and equipment used in Energy audits in Industry that can be used world wide.
Is there a link for that on the net ?
Many thanks
--amrh
RE: Energy Audit equpiment
Dear friend,
I don't think Energy audit requires any special equipments. Normally all the standard industries may have the required equipments. But I would like to know are you going to audit thermal systems or electrical systems.As you know that In general energy auditing requires some instruments to measure the total input energy and how the system uses the supplied energy .
If it is a thermal system, let us say a small industrial package type boiler instruments required are (List may not be full)
I. Energy supplied measurement
1. Fuel flow rate meter
2. Fuel & Air temperature measurement ( Thermometer)
3. Air flow meter
4. Feed water temperature & Flow
II. Energy utilisation
A. For generation of steam
1. Steam pressure & Temperature
2. Mass flow rate of steam
B. Energy in the exhaust
1. Exhaust gas analyser (which will give the composition of the exhaust products, from that air/fuel ratio, combustion efficiency can be calculated)
2. Exhaust gas temperature
C. Energy in the blowdown water
1. Blow down quantity
Most of the instruments are coming with the boiler itself.
Probably exhaust gas analyser and few temperature gauges may be required for this case.
Like this you can list the instruments required for other systems also. But before the you should know how the system utilising the supplied energy and the losses.
KMPillai.
Here is a list of equipment we use for commercial facility energy audits.  Quantity of loggers and sensors vary with application and facility size.
Fluke    39    Power Meter
Fluke    80i-500s AC Current Clamp
Fluke    TL223    Electrical Test Lead Set
Fluke    77-3    Digital Multimeter
Fluke    80TK    Thermocouple module
Fluke    AC-1a    AC Voltage Detector
Fluke    C1600    Gear Box for Meters and Accessories
Fluke    65    Infrared Thermometer
Alnor    AXD 532    Micromanometer kit
Extech    EA30    Light Meter
Mitchell 1RSAM990DW Digital Psychrometer
Onset HOBO H06-002-02 Data Logger, lighting runtime (on/off)
Onset HOBO H06-004-02 Data Logger, Motor runtime
Onset HOBO H08-006-04 Data Logger, 4 external channel
Onset HOBO TMC6-HC Stainless steel temperature probe
Telaire    7001D    CO2 Datalogger kit
Telaire    2075    Calibration kit
Onset HOBO CTV-B 0-50 amp split-core AC current sensor
Onset HOBO CTV-C 0-100 amp split-core AC current sensor
Onset BCP4.3-ON    BoxCar Pro 4.3 Starter Kit (Windows)
Canon Powershot A60 Digital camera
Simple Tech STI-CF/128    128MB CompactFlash card
Canon CBK-100 AA NiMH rechargeable battery and charger kit
Cementex GKO-10(size 10)insulating rubber gloves
