Excel and Steam Tables
There must be a way to use Excel with steam tables.
I have downloaded Water97 v13.xla. Freeware based on IAPWS-IF97. It's in metric units. I have converted the numbers back and forth. Not a problem, just a hassel.
But it's not obvious how to get at something like superheated pressure when only temperature and specific volume are known.
Anyone know the way though this in Water 97?
Is there an American units version of Water 97 available?
I can see using my own table and functions for the saturated part, but superheated is out of my league.
Thanks for the help.
Pete Jansen
Pete Jansen
RE: Excel and Steam Tables
Barring that, I can recommend Archon Engineering's steam table program. That one I know gives you the option of providing any two parameters out of five (temperature, pressure, density, enthalphy or entropy) and it calculates the rest.
A=A(density, Temperature), where A=helmholz function. So all the other properties are derived as derivatives of A.
If you know spec vol & T, you are using the natural coodinates for the correlation. The Excel table you referenced should have some background baisis which should allow you to access all properties from density + Temp. I suggest contacting the office that issued the excel functions.
I read thru the programming for the excel add-in water97_v13, and found that it is based on a different equation of state, where the primary properties are P + T. See <www.cheresources.com/iapwsif97.shtml>.
If you download the add-in , and open it in excel using the visual basic key, you can view ( and modify) the program to accept US units in lieu of metric units. . Also, there are over 44 public functions provided with the add-in, and not the dozen or so listed on the comon webpages.
1) I downloaded the Archon steam program demo. Nice program, but it doesn't have an input for steam quality. A great website for economical software.
2) I contacted that office initially, but the person is in Germany and it's freeware, so he may not get back.
3) Techware is an interesting site. Their product "XLInterp" may be new since you were there. It's an add-in for Excel that may just handle it straight away. Designed to interpolate forwards and backwards, without data being in ascending order. It seems to be advertised to work on any user designed table.
4) Embarassed to say I don't know enough Visual Basic to do either of the suggestions you made. But if you care to elaborate, fantastic.
Thanks to you all.
Hope it helps.
Dim qDataCache(100), Cnst(100)
'____________________________ Specific Volume _______________________________
Function fnVsh(P, F)
If Cnst(1) = 0 Then Initialize
B = P / 3208.234759 'Beta (ratio of P/Pcrit)
Th = (F + 459.67) / 1165.14 'Theta (ratio of degR/degRcrit)
Chi = 4.260321148 * Th / B ' Initialize Chi (ratio of v/vCrit)
Kount1 = 7
For M = 1 To 5
Call Sum2(Sum, Kount1, 0)
Chi = Chi - Sum * M * B ^ (M - 1)
Next
Kount1 = 36: Kount2 = 59
For M = 6 To 8
Top = Sum * (M - 2) * B ^ (1 - M)
Call Sum2(Sum, Kount2, 0)
Bot = (Sum + B ^ (2 - M)) ^ 2
Chi = Chi - Top / Bot
Next
Call Sum3(Sum, Bl, 0)
Chi = Chi + 11 * Sum * (B / Bl) ^ 10
fnVsh = Chi * 0.0507785289
End Function
'____________________________________________________________________________
'______________________________ Entropy _____________________________________
Function fnSsh(P, F)
' Private B, Sig, Sum, Kount1, Kount2, Kount3, Kount4, Top, Bot, Bl, M
Sig = -4.260321148 * Log(B) + Cnst(1) * Log(Th) ' Initialize Sig
' which is Sigma
Call Sum1(Sum, 0) ' s/sCrit
Sig = Sig - Sum
Kount1 = 7
For M = 1 To 5
Call Sum2(Sum, Kount1, -1)
Sig = Sig - Sum * bLil * B ^ M
Next
Kount1 = 59: Kount2 = 36: Kount3 = 59: Kount4 = 36
For M = 6 To 8
Call Sum2(Top, Kount1, -1)
Top = Top + Sum
Call Sum2(Sum, Kount3, 0)
Bot = Sum + B ^ (2 - M)
Call Sum2(Sum, Kount4, -1)
Sig = Sig - bLil * (Sum - Top / Bot) / Bot
Next
Call Sum3(Sum, Bl, 1)
Sig = Sig + B * Sum * (B / Bl) ^ 10
fnSsh = Sig * 0.02587358228
End Function
'_________________________________ Enthalpy _________________________________
Function fnHsh(P, F)
'Private B, Eps, Sum, Kount1, Kount2, Kount3, Kount4, Top, Bot, Buv, Bl, M
Eps = Cnst(1) * Th ' Initialize Eps which is Epselon (h/hCrit)
Call Sum1(Sum, -1)
Eps = Eps - Sum
Kount1 = 7: Kount2 = 7
For M = 1 To 5
Top = Sum
Call Sum2(Sum, Kount2, -1)
Eps = Eps - (Top + bLil * Th * Sum) * B ^ M
Next
Kount1 = 59: Kount2 = 59: Kount3 = 36: Kount4 = 36
For M = 6 To 8
Call Sum2(Buv, Kount3, 0)
Eps = Eps - (Buv + bLil * Th * Sum - Buv * bLil * Th * Top / Bot) / Bot
Next
Call Sum3(Sum, Bl, 2)
Eps = Eps + Sum * B * (B / Bl) ^ 10
fnHsh = Eps * 30.14634566
End Function
'______________________________ Sat Pressure ________________________________
Function fnPSat(F)
If F < 32 Then Beep: qPrint "Bad Data": Exit Function
temp = 1 - Th
Top = temp * (temp * (temp * (temp * (temp * -118.9646225 + 64.23285504) _
- 168.1706546) - 26.08023696) - 7.691234564)
Bot = 1 + temp * (temp * 20.9750676 + 4.16711732)
fnPSat = 3208.234759 * Exp(Top / (Th * Bot) - temp / (1000000000# * temp ^ 2 + 6))
End Function
'_______________________________ Sat Temperature ____________________________
Function fnTSat(P)
'Fit by Bize Not ASME Steam Tables
If P < 0.0886 Then Beep: qPrint "Bad Data : exit function"
temp = -268.633 - 0.0054 * P + 2.4417 * Sqr(P) + 32.558 * Sqr(Sqr(P)) _
+ 50.338 * Sqr(Sqr(Sqr(P))) + 285.04 * Sqr(Sqr(Sqr(Sqr(P))))
If P > 1400 Then
Del = P - 1400
temp = temp - Del * (0.000106 + Del * (0.000000343 + Del * 0.00000000013))
End If
fnTSat = temp
End Function
Sub Initialize() ' Reads ASME constants into Cnst() and bLil
'B sub 0,v ===> Cnst(1) thru (6)
qData 16.83599274, 28.56067796, -54.38923329
qData 0.4330662834, -0.6547711697, 0.08565182058
'B sub u,v and z sub u,v where u = 1 to 5
'========> Cnst(7) thru (35) (zero is flag to end loop)
qData 0.06670375918, 13, 1.388983801, 3, 0
qData 0.08390104328, 18, 0.02614670893, 2, -0.03373439453, 1, 0
qData 0.4520918904, 18, 0.1069036614, 10, 0
qData -0.5975336707, 25, -0.08847535804, 14, 0
qData 0.5958051609, 32, -0.5159303373, 28, 0.2075021122, 24, 0
'B sub u,v and z sub u,v where u = 6 to 8
'========> Cnst(36) thru (50) (zero is flag to end loop)
qData 0.1190610271, 12, -0.09867174132, 11, 0
qData 0.1683998803, 24, -0.05809438001, 18, 0
qData 0.006552390126, 24, 0.0005710218649, 14, 0
'B sub 9,v =======> Cnst(51) thru (57) bLil = Cnst(58)
qData 193.6587558, -1388.522425, 4126.607219, -6508.211677
qData 5745.984054, -2693.088365, 523.5718623, 0.7633333333 ' bLil
'b sub u,lambda and x sub u,lambda
'=====> Cnst(59) thru (69) (zero is flag to end loop)
qData 0.4006073948, 14, 0
qData 0.08636081627, 19, 0
qData -0.8532322921, 54, 0.3460208861, 27, 0
For I = 1 To 69
qRead Cnst(I)
Next I
bLil = Cnst(58)
End Sub
Sub NonDim(Psia, degF, Beta, Theta)
' Changes Psia and degF into Non-dimensional parameters
' Beta is ratio of pressure/pressure at critical point of steam
' Theta is ratio of degR/degR at critical point
Beta = Psia / 3208.234759
Theta = (degF + 459.67) / 1165.14
End Sub
Sub Sum1(Sum1, iFlag)
'Sum1 is sum of (N1*Beta(0,v)*Theta^N2) for v = 1 to 5
' where if
' iFlag = -1 then N1 = v-1
' N2 = v-2
' else N1 = v-2
' N2 = v-1
'Private LilV, N1, N2
Sum1 = 0
For LilV = 1 To 5
If iFlag Then
N1 = LilV - 2: N2 = LilV - 1
Else
N1 = LilV - 1: N2 = LilV - 2
End If
Sum1 = Sum1 + N1 * Cnst(LilV + 1) * Th ^ N2
Next
End Sub
Sub Sum2(Sum2, K, iFlag)
'Private Prod
Sum2 = 0
While Cnst(K) <> 0
Prod = Cnst(K) * Exp(Cnst(K + 1) * bLil * (1 - Th))
If iFlag Then Prod = Prod * Cnst(K + 1)
Sum2 = Sum2 + Prod
K = K + 2
Wend
K = K + 1
End Sub
Sub Sum3(Sum3, Bl, iFlag)
'Private LilV, Prod, temp, L1, L2, Blprime
L1 = -34.17061978: L2 = 19.31380707
Bl = 15.74373327 + Th * (L1 + Th * L2)
Blprime = L1 + 2 * L2 * Th
Sum3 = 0
For LilV = 0 To 6
Prod = Cnst(51 + LilV) * Exp(LilV * bLil * (1 - Th))
If iFlag <> 0 Then
temp = 10 * Blprime / Bl + LilV * bLil
If iFlag = 1 Then Prod = Prod * temp
If iFlag = 2 Then Prod = Prod * (1 + Th * temp)
End If
Sum3 = Sum3 + Prod
Next
End Sub
Calm down, check this:
http://www.chemicalogic.com/steamtab/companion/default....
Your welcome.
Dracula
