UG NX2 VIEW FIT
UG NX2 VIEW FIT
UG NX2 VIEW FIT
I have a problem with UG NX2 FIT & Replace View for some parts. It does not show the part, It shows a blank screen.
But orient View works. Any body has had this problem?
thanks, fsi
RE: UG NX2 VIEW FIT
I've noticed the problem also when I use view--> operation--> rotate, as soon as I rotate the view, it dissapears, and I cannot get it back, not matter what. Anyone else run into this?
-Derek
DL Engineering Services
specializing in CAD Design Consultation Services
www.dl-engineering.com
RE: UG NX2 VIEW FIT
I am using UG NX and don't see any of those problems.  Perhaps UG has a patch.  I would check with their tech support.  Also, make sure that the box labelled "Fit" is checked so that it does fit the view to the screen.  Good luck.
RE: UG NX2 VIEW FIT
sociallyinept
Where is the box labelled "Fit" ?
Thank you
fsi
