Pro-E Skeleton Files -- anyone use them
I just received a Tar file of an assembly. I opened it and moved the resulting parts, drawings, and assemblies to a directory. When trying to open the final assembly I got an error message that it could not find the skeleton file. I have never used this feature and am not sure what the problem is.
I can see the skeleton file but can do nothing with it. Any ideas out there?
Dave
Dave
RE: Pro-E Skeleton Files -- anyone use them
Is the skeleton part suppressed?
It should be the first assembled feature in the model tree.
Did you try opening hte skeleton part then your assembly?
We use a part file instead of the Pro/E skeleton type format. I have not had any problems such as yours.
I will have to try to use this and see how it works.
Dave
thanks for giving a understandable explanation
for skeleton model i was just searching for that only
