Non-constant acceleration
I was experimenting with electromagnets and I noted how a neutral steel ball being attracted to one end of the cylindrical electromagnet had an increasing acceleration. Because, as the distance between the steel ball and the electromagnet decreased, the force attracting it increased; thus increasing the acceleration. Now, assuming the electromagnet is held in place, I was curious as to how I could work out the velocity of the steel ball just before it hits the electromagnet when placed and released at certain distances from the electromagnet. And also when rolled towards the electromagnet at a steady velocity (assuming no friction). I am quite sure you would have to use definite integrals but I am not sure at to how you would work this out.
RE: Non-constant acceleration
