Monitoring make-up water
We have had a couple of leaks in remote areas of our chill water systems that went undetected for a while because there is no way to check every area all the time for leaks. I was thinking of installing a flow meter and some kind of timer in the water make-up line to the closed loop chill water system to give an alarm to the operator when the system is making up water. If the system continues to run, he knows he has a leak somewhere. Has anyone ever done (or seen) something like this and can share how you did it?
RE: Monitoring make-up water
Can you email me the specifics on your flow meters? This sounds like it will work in this application. Please send e-mail to blackwell_kev@yahoo.com. Thanks for your help
