parametric bent rod method? (please!)
Help please! The prodigal CAD user seeks guru! (turned my back on UG in '91....but I'm back now!)
I need to create a bent piece of rod/tube (brake pipe) and the model must be parametric. The tube is a series of straights with constant radii bends separating them. I have tried <curve op><combined project> but don't think this will get me the result I require. There must be a way that I can enter a series of xyz vals (using spreadsheet even?) join the dots and fillet the bends before using a sweep operation? if so will the points be modifiable and the part update retain the fillets? (this is a MUST!)
Should I create each straight and bend on a sketch using parametric datum planes?
Ford have a prog file that does these parts in 20seconds and tabulates the co-ords for use in the dwg - something similar must be possible in UG??? Thanks, Darce.
RE: parametric bent rod method? (please!)
I built a complete rollcage this way.
-Dave
http://www.moslerauto.com
Respect. Once did a mid-engined spaceframe in I-Deas, was not the easiest of jobs!
Darce
darcy_alan hotmail.com
Good Luck,
Chip Tasker
Machine Designer / CAD analyst
chptskr@aol.com
