? on ANHEDRAL, DIHEDRAL, & conventional STABILIZERS usage.
What are the determining factor that a designer uses to determine which tail configuration they use. I understand the reasons for the "T-tail configuration" when used with rear engined aircraft.  Some examples of the different configurations in use are:
The Dassault FALCON 50, 90, 900, 2000 and FX all utilize the middle span ANHEDRAL style stabilizer, the FALCON 20, however, uses the slightly DIHEDRAL mid-span stabilizer.  CITATION II, V, 500, and 550's all use a DIHEDRAL configuration.  LEARJETS use the T-tail configuration exclusively, the HAWKER-SIDDELY 125 use a T-tail configurtion, and the anachronistic WESTWIND uses what looks like, a low conventional stabilizer.  Any explaination on the positive and negatives of each configurations would be great.  Thanks everyone.
RE: ? on ANHEDRAL, DIHEDRAL, & conventional STABILIZERS usage.
A full answer is long and involved.  It may help to shorten the answer if you would say why are you asking.
No specific reasons really, I just want to know if there is a criteria that dictates a particular choice. Any links to books that could provide in-depth explanations would be great as well.  Thanks
Usually the boss likes one configuration or another.  The design always starts there.  I remember a light twin design where the President of the company wanted the tail to look like the tail on the F-5.  We just about never got that to work right.
The tail's vertical placement is a tradeoff between aesthetics, tail arm, and desired distance from the propwash or jet engine exhaust.
T-tails sometimes have anhedral because that was an early solution to dynamic cross-coupling in flutter problems.  T-tails don’t seem to always have anhedral anymore.
Other than that, dihedral or anhedral is usually added to a tail after wind tunnel tests in order to tailor the roll/yaw characteristics of the airplane.
Thanks Miper, that makes sense to me now.  I appreciate your reply.
