Command Interrupted while Drafting
I am having problems while drafting in Catia V5 R10 SP4. Every time I do a drawing I am able to work with it for about 5-10 min and then I get the error message "Command Interrupted" and then "Click OK to terminate" and Catia closses. It doesn't matter what drawing I am working with or what models the drawings are from. I have tried cleaning out my CATSettings and running CATDUAV5 (clean) but that was no help. If anyone has any suggestions that would be a big help.
Thanks in advance
Thanks in advance
RE: Command Interrupted while Drafting
i think that...this error is licence error...you check that your CATIA platform is right?(P1, P2 or P3) ... is it ok?
i also get an error like that...just because using a wrong flatform install disk.
goodluck
0901
I am having the same issue but it's while opening the file that this issue occurs but i am running r12 without a service pack so hopefully things will work out for me the way they did for you.
Thanks for the tip, Tim
