What is the most diference between ASME against ASTM
Dear ALL
Kindly advise me, what si the most diference between ASME against ASTM ?
Please also advise me whether mill symbol must be put on the Steel Plate SA 516 Gr 70.
Your reply should be sent to ibnu@sbs.co.id
best Regards
Ibnu
best Regards
Ibnu
RE: What is the most diference between ASME against ASTM
Appendix A
Mill Marking-SA-516 refers you to SA/A-20 (mandatory) see
13.1.1
ASME provides codes and standards, and the ASME Boiler and Pressure Vessel Code includes material specifications for use with that Code, in Section II of the Code. They adopt, and sometimes modify, the ASTM specifications, and the number of the ASME specification begins with an S, e.g. SA516. These are specifications approved for use with with the ASME Boiler and Pressure Vessel Code.
You can get dual stamped (e.g. A516/SA516 materials) indicating compliance with both specifications.
