Mannings n for PVC
Mannings n for PVC
Mannings n for PVC
I'm looking for a good reference for the use of a "n" value of 0.010 or 0.011 for PVC.  Client standard is minimum of 0.014.
RE: Mannings n for PVC
Although you might use a Manning's n of 0.010 for clear water almost every review agency will require you to use an n of 0.013 or 0.014 for stormwater or sanitary flows.  The theory is that the pipe walls will become partially clogged of covered by biofilm.
Good luck
cvg, Here's a table chock full of Manning's n values for all sorts of materials.
www.lmnoeng.com/manningn.htm
Hope this helps.
saxon
just what I needed - thanks
