Handrail distance from landing
Can anyone tell me what the vertical distance is from the finished floor on a landing to the top hand rail? Is it 3'-6, and the top handrail on the actual stair part 2'-10 from nosing line? This is for metal stairs, using C12 x 20.7, with pour pans and deck. Thanks.
RE: Handrail distance from landing
The National Building Code of Canada says for landings, 1070mm ~42", for stairs, not less than 800mm ~32" and not more than 965mm ~38". I would check with you local building code.
VOD
Good luck.
Also a google search on "OSHA handrail" will give you many supplier web sites that have sketches and downloadable proprietary information.
For industrial stairs, OSHA is inconsistant in the height of the guardrails for stairs and landings. OSHA allows the stair top rail to be used as a guardrail at 36 -37". However, at landings, they require a 42" guardrail. The best (safest) solution is what the life safety and many building codes require: provide guardrail of 42" at landings and stairs and also have a continuous handrail at 36" along the stairs.
http://www.osha.gov/Publications/osha312...
