History of Machine Tool Accuracy
What a great topic! (Born of an idea in the "First Use of Threads" thread...)
I would venture to guess that the modern accuracy of machine tools began with guys like James Watt, Eli Whitney and L.S. Starrett. However, a standard has to have a base measure in some form, so I would venture that the history of the Meter would be relevant at some point. I've attached two articles below that might get the thread started:
History of the Machine Tool:
http://www.darex.com/indurevo.htm
History of the Meter:
http://www.sciam.com/askexpert_question....
RE: History of Machine Tool Accuracy
Cheers
Greg Locock
There's a series of books authored by David Gingery that details how--using hand tools--you can build a completely functional set of metalworking machinery. The process begins with making yourself a simple furnace and foundry to sand cast aluminum. Aluminum sand castings then form the basis of the next project: the lathe.
The lathe is constructed with the knowledge that inaccuracy in most of the parts of the machine doesn't affect the accuracy or function of the finished machine. Components that require accuracy are generally finished by hand scraping, just like Whitworth's surface plates. Mating components are constructed with only sufficiently good fit; designed with adjustment to take up slop/lash. By the time you start to need precisely-turned components to finish the lathe, the lathe is complete enough that it can be temporarily rigged to machine its own parts.
Once the lathe is completed to that point, you're set. Further books in the series use your manual skills and your new lathe to build a metal shaper, horizontal milling machine, and drill press. These are then used to go back and make the gears, dividing head, etc., to add screw-cutting ability to the lathe. At that point, the world's your oyster.
Now, being a modern series, certain short cuts are taken; cheap threaded rod and cold-rolled steel abound. But the point is nothing that it required for the lathe can't be created with a surface plate and some hand scraping or filing, with some thread chasing thrown in.
It's an interesting project and probably quite closely follows the developmental path of early toolmakers in most regards. Google search 'Gingery Lathe' for examples.
I hope that's interesting.
I was told how in the 20's my father was working with a lathe trying to produce a very accurate lead screw for a ruling machine. When they had made the most accurate lead screw that the lathe could make they installed this in the lathe and instead of a metal follower on the lead they used a hard leather follower to smooth out the imperfections of the lathe's lead screw. I saw references to this same procedure in the 50's in making diffraction gratings.
The introduction of ball bearings and the development of a good 4 jaw greatly helped the lathe business. Another big improvement came with the barrel micrometer. Prior to its’ introduction the caliper and divider were king. Both my fathers and grandfathers tool boxes had at least 50 pairs each of all descriptions.
One thing that allowed improvements in accuracy was a lot of the designs were made with comparisons to one component of the piece. In my father’s old books there is a design for a packing gland for shafts up to 1 ½" that every measurement is referenced to the stem diameter.
Accuracy is a always been dependent on one thing, the skill and dedication of the machinist
In your history about accuracy of machine tools, you should not forget the Pratt & Whitney company.
On their history page at http://www.prattandwhitney.com/history.htm they have a copy the book "Accuracy for Seventy Years 1860-1930". The book has a lot of information about machine tools and measuring instruments. On page 36 is a drawing of the Rogers-Bond comparator and on page 38 is a "Interferometer capable of measuring to fractions of millionths of an inch".
Friar Tuck of Sherwood
“Foundations of Mechanical Accuracy”
Wayne R. Moore - 1970
I believe it is still available from Moore Special Tool.
