Linked Notes Across Sheets
We need to link a note in each of our sheet formats of a multi-sheet drawing to a configuration specific property of the model referenced in Drawing View 1.  Not a problem in Sheet 1, but in all subsequent sheets Drawing View 1 is not available.  Any ideas?
RE: Linked Notes Across Sheets
Turn your linked note into a Block.  In SW03 the block properties will allow you to insert the same block on different sheets.  When you change the Block contents, all the instances will update accordingly.
MadMango
"Probable impossibilities are to be preferred to improbable possibilities."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
