Heavy Oil Economics
Heavy Oil Economics
Heavy Oil Economics
Anyone who has worked in Heavy Oil probably sympathizes with me here.
I am a junior engineer at my company, and one of my tasks is to track the economic performance of engineering enhancement projects. For light/conventional oil and gas production it is s simple enough task. I compare predicted costs and incremental production to what actually happens after the work is complete.
However, when I get into the heavy oil fields, it isn't as simple at all. There are virtually no declines for heavy oil production on a rate vs time/ rate vs cum. graph... all I end up seeing is a jump in rate whenever a workover is done (pump size increases, etc) steady production for a while and then a virtual suicide until the next workover.
So my problem is that I can't predict incremental reserves for my economic forecasts.
Which brings me to another daunting thought. Almost every well I look at in my heavy fields reqires some sort of enchancement project every few months. Clearly, I cannot evaluate the success of a project on an annual basis, nor can I evaluate the success of a well on a project to project basis.
Any thoughts or suggestions on my plights?
~Patrick McG.
RE: Heavy Oil Economics
Maybe I should be a little more clear with my request.
What sort of expectations should I be placing on my heavy oil operations? It is just the nature of the beast that these wells are worked over every few months, so clearly it is not a failing project if it sees increased production.
Any thoughts?
~P. McG
PatMcG,
I do not do economic forecasts on a regular basis nor do I have the "credentials" to do them.  I have had to try and make forecasts on "hard to forecast" projects before.  My suggestion would be to base the prediction on past performance of a group of similar or near by wells.  Check out the past production/workover histories and see if you can find a strong enough trend to base assumptions on.  My bet is you will have no problem finding a strong trend.
SPE standards for reserves estimation allows it.  Sometimes it's all you have.  Sometimes it's the best predictor.
Cliff
