Baseband and Synthesiser hopping in GSM
Can someone confirm wht I believe is correct ref freq hopping in GSM.
Baseband hopping allows the hopping over all transceivers in a cell (Bar the BCCH chsnnel) on a per tdma slot basis.
Synthesiser hopping allows hopping on a per transceiver basis only. i.e all you are really doing is hopping across the eight timeslots on the same transceiver.
Can anyone confirm this
Thanks in advance
Billy C
RE: Baseband and Synthesiser hopping in GSM
Baseband - Call hops between different TRX each of which is on a different static frequency.
Synthesized - Call stays on same TRX but the TRX hops between different frequencies.
