about electronic motor control
hi everyone, im electronic engineer, but i have not found any motor related question refered to electronics, is it unusual to have a electronic control for a squirrel cage motor ie?
in the industry do any of you deal with that?
are those controllers expensive? easy to find?
thanks
killa
thanks
killa
RE: about electronic motor control
VFD are almost a standard (at least in the USA) where speed control of a squirrel cage motor is required.
The costs have come down greatly, and in most cases it is not even a factor. They are very comparable to say a star-delta starter of a similar rating.
Solid state reduced voltage starter also comparable (10 to 15% more) than a standard starter.
All of these are easy to find and carried by all leading electrical equipment manufacturers.
http://www.amazon.com
and under books, type Induction Motors that will return 48 books
http://www.geindustrial.com/cwc/products...
for typical industry motor drive products with applications
or just surf web for more info (sometimes very attractive in colors, animations, academic level, etc.)
