PCA Circular Concrete Tank Compression Ring
When going through PCA's "Circular Concrete Tanks Without Prestressing", there does not seem to be any accounting for loads on the outside of the wall. I've heard references to compression ring action which makes sense but could someone tell me where I could find some documentation on this. I'm also concerned that for larger diameter tanks, the compression ring would tend to start acting one way instead...could someone please give me some direction here...Thanks in advance
RE: PCA Circular Concrete Tank Compression Ring
See Formulas for Stress and Strain by Roark or Theory of Elastic Stability by Timoshenko & Gere. There is little problem with this external loading.
Best, Tincan
