Aluminum Casting Resources
Hi All,
Can anyone reccomend books/papers on aluminum castings (with an automotive slant)  I've been searching through SAE, ASTM and the Aluminum Association, but the number of choices is bewildering.  Is there a good single starting source on this topic?
Thanks In Advance,
Scott
RE: Aluminum Casting Resources
Try the ASM handbooks & go from there.
There used to be a series of handbooks put out by ALCOA that had everything you ever wanted to know Aluminum.
You might try their website:
www.alcoa.com
