Object Snap Pop-Up
Object Snap Pop-Up
Object Snap Pop-Up
I would like to know if anyone can assist in AutoCad 2002 with programming a Microsoft Intellimouse scroll wheel to bring up the Osnap Pop-Up to select a pick point.  I was able to use this function with different mouse in AutoCad 15.  I have assumed it was a config.issue in AutoCad.  Am I wrong?  Any assistance is appreciated.  Thank you.
BADennis
RE: Object Snap Pop-Up
Set MBUTTONPAN system variable to zero
Thanks Binary.  That solved the problem.  Much appreciated.
BADennis
