Solidworks to design aircraft structure?
I'm doing some research on Solidworks. Is anybody using solidworks to design FAA certified aircraft structure? If so, is it new design or sustaining? Have you had success with lofts/splines/large assemblies?
Thanks for the input,
Luke
Luke
RE: Solidworks to design aircraft structure?
Bill
I have also noticed that Pro/Engineer or even Rhino are much more capable programs for lofting and creating surfaces.
It all depends on what you are used to and what you are comfortable with.
Hombre
