Custom Property write to Density and Hatch Pattern
I need to drive the density value and hatch pattern for a SW part file from corresponding Configuration Specific Properties. Any ideas?
RE: Custom Property write to Density and Hatch Pattern
For density, perhaps you could copy the body and assign a density to the copy. Use "Delete Body" to get the original out of the way, and suppress the copies in the various configurations.
Our PDM (Smarteam) can not write to system properties, only cust/config. specific so after that it's a SW macro that will have to populate the system properties. We populate material part number, description, part number etc. I'm just wanting to get some engineering data too.
To set density, you can use:
Part.SetUserPreferenceDoubleValue swMaterialPropertyDensity, density
For crosshatch:
Part.SetUserPreferenceStringValue swMaterialPropertyCrosshatchPattern, sCrossHatchName
Brenda
I forgot that you're using SmarTeam. SmarTeam also employs event-type "hooks" to which you can attach scripts to be run when triggered by certain activities (for example, before check-in, after check-out, etc.) At this point your script that writes values from your custom properties to density and cross-hatch could run.
--Brenda
