Acad 2004 quick commands
Up until autocad 2004 you could customize your keyboard commands by changing the acad.pgp file. So when I installed 2004 I located & changed my .pgp file and thought all was good. I started using 2004 and my changes to the .pgp file have not changed anything. I have been using the same altered commands for years and am not about to change.
How do I change the quick commands????? This is driving me nuts.
RE: Acad 2004 quick commands
there's a new folder for Your own acad.pgp. Search on c:\...<userneme>...acad.pgp
Or use "aliasedit" from ExpressTools1-9
Lothar
AutoCAD 2004 based products have changed the default support path settings from previous AutoCAD versions. AutoLib needs to add its entry into the ACAD.PGP file. Select BROWSE to locate the ACAD.PGP file. By default, the location of this file is at:
C:\Documents and Settings\USERNAME\Application Data\Autodesk\AutoCAD 2004\R16.0\enu\Support
Regards Lothar
I added "rc" to be "_revcloud" but it doesn't work. I get a "Unknown command "_REVCLOUD"" response. If I type in "_revcloud" it works though. If I pick it from the draw dropdown menu it works as "_revcloud".
I'm baffled and confused and wasting entirely too much time with acad2004.
Express -> Tools -> Command alias editor
after editing the acad.pgp-file in the support-folder You have to reload the file
-> "_reinit"-> check pgp-file-> enter
Regards, Lothar
