Help! "save as" only gives me a command line.
I have noticed that when I use "save as" as well as other commands that I am only getting to use the command line now. I dont have the option to use a "Windows" drop down box. This is very annoying.
Anyone know the toggle to change this?
Thanks in advance
D Rogers
Thanks in advance
D Rogers
RE: Help! "save as" only gives me a command line.
"FILEDIA" @ command prompt.
Initial value: 1
Suppresses display of the file dialog boxes.
0 Does not display dialog boxes. You can still request a file dialog box to appear by entering a tilde (~) in response to the command's prompt. The same is true for AutoLISP and ADS functions.
1 Displays file dialog boxes. However, if a script or AutoLISP/ObjectARX⢠program is active, AutoCAD displays an ordinary prompt.
hope this helps
Intel P4 1.7 GHZ
768 RDRAM
Win 2000 Pro
Autocad 14, 2002 with EP 2.3.1
Thank you.
