How much external force can pipe takes before it deforms?
I have a 300psi dry air line that needs to run under a crushed gravel roadway in a switchyard. The current plan is to use 1" Sched 40 SS. I'm trying to decide if the pipe needs to be protected from the forces of a truck driving over top, or whether laying it 1' underground will be enough. There must be a formula for this.
Suggestions?
Suggestions?
RE: How much external force can pipe takes before it deforms?
Try with API RP-1102.
Shubijj.
1- depth of laying = I sugest 1 m cover to protect it from dynamic & static machionary loads .
2- apply suitable coating and corossion allowance to its thk.
