acad2004-transparency in shademodes
There is a new feature in ACAD 2004 which allows transparency in 3D. However - object are not displayed correctly - object that should be visible are not. Is it possible to switch the transparency OFF? thanx. Paul
RE: acad2004-transparency in shademodes
I'm not sure what you mean by this 'new' feature - autocad has always displayed 3D in wireframe (or transparent) It sounds like you've got it on 'hidden' shade mode. Goto menu view/shademode/2Dor3D wireframe and if that doesn't work i must have misunderstood.
