API 620 App Q
API 620 App Q
API 620 App Q
Can a tank build according to API 620 App Q (refrigerated) inspected using the API 653 standard??
RE: API 620 App Q
Yes, API-653 may be used for the inspection of any tank built to a recognized Code or Standard.  The only problem is that the evaluation of the inspection results are not covered adequately in API-653.  You would require the services of a Tank Engineer to sort those issues out.
Steve Braune
Tank Industry Consultants
www.tankindustry.com
RE: API 620 App Q
You should see API-620, Appendix R for refrigerated products or fluids.
