cross country pipline
Is there any regulation regarding the liquid that can be maintained in a cross country pipeline. What is specifically required to be known is - Is it correct to leave an underground/above ground pipeline with a line content of gasoline after operations. If not what is the pipeline kpt with during the time it is not being operated.Could someone help me out on this
RE: cross country pipline
Rule and regulation vary from country to country.
Best regards
Morten
U should also clean the line by flushing with water to make sure it is not left with flammable fluids.
A general regulation that holds for any country is that pipelines and ancillary structures are abandoned in a manner that will not pose any hazard to the environment.
Best regards
Morten
