How can U Flange Sheetmetal Hole?
Can anyone suggest a procedure to flange a cutout hole in thin-sheet metal.
ie: 5" Dia. Hole with .25" lip at 45 degrees around the circumference of a round (or sometimes oval) cutout.  (a.k.a. Lightening Holes)
Any suggestions would be useful ..
RE: How can U Flange Sheetmetal Hole?
Create a Forming Tool, check SW Help Topics.  It's your best solution.
MadMango
"Probable impossibilities are to be preferred to improbable possibilities."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
how about using a sweep?
you might check in your Feature palette\forming tools There might be one already there. If so, you can modify it and resave it.
Scott Baugh, CSWP
3DVision Technologies
http://www.3dvisiontech.com
http://www.scottjbaugh.com
FAQ731-376
When in doubt, always check the help
