Finding apropriate valves
Hi!
I´m conducting a high temperature project with liquid Dowtherm A (375ºC). As i never worked with High Temperature valves i´m having some dificulty selectind appropriate control valves for small tubes(1/2 and 1'').
Can anyone tell me about some valve providers? I´ve found FLUVAL and OMB VALVES but they don't have exactly what i´m looking for.
thanks
RE: Finding apropriate valves
thanks.
What i´m looking for is a flow control valve, acording to a temperature reading. Fluval as control globe valve, but the smallest size they have is 2''
You might want to check out the Fisher Baumann product line.
The 24000S series control valves are available in metal seat construction and can take more than 375C depending on the construction of the valve and the service pressure.
www.baumann.com
thanks once again.
My problem is now solved.
Baumann's control valves are what i´m looking for.
