Only Pruxy server is Working
Dear Friends
I shall be too much grateful to find a better solution to the problem of Internet Server Provider that turned to be a problem of Windows. I am using Widow 95.
My ISP has two services one with proxi and the other without proxi. Usually I am contacting the web with the proxi server on. I found lately that the connection without the proxi is not working either using the IE 5.2 or the Netscape 4.7. In both browsers they are looking or try to connect the site I am demanding but they so not succeed in opening it. This problem does not occur when using the proxi server and the connection is normal. The same problem occurred using two other ISP services that do not have proxi service. The solution suggested by the ISP service is to change my modem from Rockwell 33 to some other modem higher like 57. I already changed the modem without success. Now some friend told me that I must format my hard disc as this problem is a problem of the operating system and it is better to use Window 98. Ism
