Modeling a curved compression spring
I need to model a helical compression spring that is going around a curve. As of now, I have modeled the spring as a tube, one sweep feature. Is there a way to do this? I was thinking of using 3D points, and then sweeping the points. I do not know how to generate the 3D points though. Also, I would like to be able to show the part in the different working lengths, and straight too in the same configuration.
Thanks.
Thanks.
RE: Modeling a curved compression spring
http://www.mikejwilson.com/solidworks/so...
Page 5 has an Adjustable Curved Helix that I think is right up your alley.
MadMango
"Probable impossibilities are to be preferred to improbable possibilities."
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
