MDL Application Loading
How do you keep an MDL application loaded.  I have loaded the application and then the next time I exist Microstation and come back in, I have to reload the application.
RE: MDL Application Loading
under the workspace - configuration menu select design applications, just choose the the one you want under available applications and hit add.
If you are familiar with MicroStation Configuration Variables, you can automatically load the .MA when files load. You can add the following line to your USER.UCF:
     MS_DGNAPPS > x:\...path...\AppName.MA
Where X is the drive, ...path... is the full path and AppName is the name of the MA you want to load. Careful though - this will load the app everytime you start MicroStation!
