Regulations/Standards for Gamma rays Shielding
Hello, I am looking for master specifications or international regulations on Gamma ray shielding for Industrial Equipment. The Radioactive isotope is Cobalt 60 and the particular equipment is a radioactive concentration transmitter for a dredge.
A.
A.
RE: Regulations/Standards for Gamma rays Shielding
Patricia Lougheed
Please see FAQ731-376 for tips on how to make the best use of the Eng-Tips Forums.
http://www.osha.gov/SLTC/radiationionizi...
Radiological protection to minimise doses to operators and the public involves more than shielding. Typically you look at distance, time of exposure AND shielding to optimise the design of your plant.
I would anticipate that most of the legal restrictions you will find will be to limit the dose rather than specify shielding thickness, however you could look in books on nuclear engineering to find attenuation coefficients of various materials.
Try the "Reactor Handbook 2nd Ed. Volume IV, Gamma Ray Attenuation", Blizard EP and Abbott LS, Interscience 1962 or "Introduction to Nuclear Engineering 3rd Ed.", Lamarsh JR and Baratta AJ, Prentice Hall 2001. The former is qute old but once you have located it have a look around the shelves and see what else is in the near vicinity! Since you have a cobalt source the energy of the gamma is well known but you will need to know the activity of the source to use the various graphs/tables.
Regards, HM.
No more things should be presumed to exist than are absolutely necessary - William of Occam
