PLC to Excel How can I Start a Macro From PLC
I am using Excel 2000 with a SLC503 Allen Bradley.
How can I for example
If N7:1/0 = 1 Then run a macro.
Is there some way of monitoring the PLC information and immediatly reacting to it and this is the key WITHOUT LOOPING A MACRO TO SCAN DATA.
Note I am familliar with how to communicate just want to start a macro base on data change.
Appreciate yours solutions and or comments
Best regards
Raymond
RE: PLC to Excel How can I Start a Macro From PLC
Ray, I suggest you try posting this questions in the PLC forum on this site (Forum791) and perhaps consider posting at www.plcs.net as well.
Try this
ActiveWorkbook.SetLinkOnData "<DDE link Info e.g \\PCName\Aplication|Topic!'N7:1/0'", "MyMacro"
I've used this a lot to monitor change in values you have to check as it runs macro when value changes not just when it equals 1.
Jezz
