I deas has been bought by Unigraphics!
RE: I deas has been bought by Unigraphics!
but u have to believe this. this is business. Now we have to see what happen on product front
Sorry Bud im new to this s!@t so I hope you indeed
did get this.....
Im hoping someone will chit chat abit
about how good or bad SDRC is.
Im hoping its great but wouldnt mind
a REAL opinion if you know what i mean.
THANKS.......E
If you want my personal opinion on I-DEAS. It's decent high end modelor, with good FEA tools. The drafting package is bad, I can't tell you how many times I've had to redo a drawing because I changed one little thing in the model, and the drawing would refuse to update, or would refuse to update with any dimensions. There is basically no "undo" command. It only works for one step, so if you refresh your view, thats your one step. I-deas is not stable. It will often just do something it doesn't like and then disapear. The sheet metal tools are bad. You can not modify your parts in the flat and then refold them. A must for sheet metal parts. Often times you can not add any thickness to the parts after making them sheet metal. Not a singal sheet metal part I have ever looked at from Ford has had a thickness.  My experience would be to tell you to go buy SolidWorks, as it's inexpensive, compared to I-Deas, Easy to learn, and powerfull enough to handle anything I've ever done.
Will
