Orifice Plate sizing
Im looking to size the hole dia of an orifice plate in quite a hurry... can any 1 help...
i have the following info:
Op Conditions:
Seawater (SG of 1.0 is acceptable for calc.)
upstream pressure: 5.5 barg
therefore pressure drop: 3bar
flow: 10L/min
OD: 12.00mm (+-0.1)
thanx guys,
keep up the good work...
Matt
Op Conditions:
flow: 10L/min
OD: 12.00mm (+-0.1)
thanx guys,
Matt
RE: Orifice Plate sizing
To size the orifice plate quickly, try the free software from flowcalc32, the programme will calculated in accordance with ISO 5167-1.
Here is the link : http://home.swipnet.se/controlengineerin...
Hope this help
Michael
Pipe stress engineer
the flow rate specified is so small as to guarantee that pluggage will occur unless the sea water is completely filtered and properly sterilized. in any event you'll be cleaning your orifice more frequently than not. great if you have nothing else to do, hence the comment about using a valve.
I can give you an estimate of the RO if you can give me the wall thickness or ID of the tubing you plan to use.
