EARTHING(GROUNDING) TANSFORMERS
1.WHAT DO THEY DO EXACTLY?
2.IN WHICH SITE CAN I READ ABOUT THEM(AND ALSO SEE THEIR PICTURES)?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
EARTHING(GROUNDING) TANSFORMERSEARTHING(GROUNDING) TANSFORMERS(OP)
2.IN WHICH SITE CAN I READ ABOUT THEM(AND ALSO SEE THEIR PICTURES)? Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: EARTHING(GROUNDING) TANSFORMERS
i dont know any site about this subject, but the way is that;
there are two point on transformer first one for netural ant safety grounding.
for grounding; first you have to use a cu plaque (1m*1m size) and you have to bury it to a ground. but first you have to measure ground resistance it must be max 1000 ohm(as i remember) if not you can chance the ground type.
netural also have same kind of plague, netural and grounding plaques must be burry opposite site of the transformer.
x TR x
netural plaque ground
1. Mason C. R., "The Art and Science of Protective Relaying," John Wiley & Sons, New York, 1956, page 268 "Grounding Transformers"
Reference 1 includes the y-delta and zig-zag grounding (= earthing in some Countries or Territories) transformer explanations and applications. It features schemes without direct connections of grounding transformers to the feeder (or downstream power distribution network) having load being protected by the grounding transformer against ground faults.
2. Beeman D., "Industrial Power Systems Handbook," McGraw-Hill Book Company, Inc., New York, 1955, page 348 "Grounding Transformers"
The grounding transformers may be connected directly to the feeder (or downstream power distribution network), and then they are treated as normal transformers from the grounding protection schemes standpoint. Again y-delta and zig-zag transformers are treated. Zig-zag transformer is usually smaller since it does not have the secondary windings; however, it is rated for very short time of fault duration and then fault must be tripped. y-delta transformer is usually used for the longer fault duration to allow time for its clearance.
