insulation in concret mix
how can i do a mix of concret for a wall that i want to be insulated.
tank you.
tank you.
insulation in concret mixinsulation in concret mix(OP)
tank you. Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: insulation in concret mix
In other words expanded polystyrene (Dow SM board or equal) is fastened to the desk and then held in place by slurry of concrete.
It sounds like a typical hot process roof where the tar holds the insulation in place instead of the concrete.
The only time you would ever mix an insulation into the concrete mix would be for lightweight concrete where something like vermulicite would be used not as insulation but as a lightweight filler.
Rick Kitson MBA P.Eng
Construction Project Management
From conception to completion
www.kitsonengineering.com
If it is not a basement wall, you can skip the dampproofing. If you are in an area that is may have high groundwater you should use a waterproofing system on the wall with waterstop in the construction joints of the wall.
This works well for basement walls. The form cost is higher but the savings in labour and the fact that the walls are then insulated result in overall cost savings.
