Transformer Oil Reclaimation
Hi
Does anyone have info regarding comparisons between reclaiming of (older) paraffin based oils vs. Naptha based oils?  Are the ratios of Fullers Earth per unit of oil the same for a given lift in IFT?
Also, what about the Neut values, do they change similarly and does anyone have any experience processing paraffin oils, do they foam badly?
Thanks all!
